I'm looking to replace a couple of non-polarized caps with polarized caps. Is this safe to do or no? The values are the exact same and I have them on hand is why I'm asking. Thanks in advance,Greg
Non-polarized to polarized?
Not in that way. You have to make a non-polar out of 2 polarized electrolytics back to back. There was a discussion here about it recently, can't remember where.
The negative ends of the 2 caps are connected together, each cap needs to be double the capacitance of the value you want.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
non polarized (NP) caps are usually electrolytic caps designed for passing an AC signal, like audio. Thus they are found in (cheaper) speaker crossover networks. Only a few type of caps are polarized, famously standard EL and tantalum caps. Nonpolarized EL caps are often two polarized EL caps attached +/- and are a compromise, but there are millions in various audio circuits where they do AOK. If they need to handle AC they start out as NP caps and need to stay that way.
Originally posted by TarheelTechinTraining View PostI'm looking to replace a couple of non-polarized caps with polarized caps. Is this safe to do or no?
There was a trend a few years ago to install non polarized caps as cathode bypass in tube pre circuits. Of course all kinds of positive claims were made. "Tastes better!" "Less fattenng!" Seems to have gone away now.This isn't the future I signed up for.
Originally posted by TarheelTechinTraining View PostThanks all, the caps are 22uf/50v and are used in the bias voltage of a JTM60. I'll just order some new(same) ones. G-one I saw that thread on back to back caps to make a NP cap from polarized.
I take non pols as a poor substitute for film, to be used only in the cheapest speaker crossovers or in circuits where polarity is unpredictable.Last edited by Leo_Gnardo; 05-13-2014, 12:40 AM.This isn't the future I signed up for.
The caps the OP is referring to are actually coupling AC- not filtering it. Here's a link to the schematic. (see lower left).
http://www.drtube.com/schematics/marshall/j600-61-02-1.gif
Edit: You got me Leo! I posted this before your edit. That said, I agree. Film caps would be better here."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostThe caps the OP is referring to are actually coupling AC- not filtering it.This isn't the future I signed up for.
Well, those are voltage doublers, probably fed from some windings designed to eventually get +/-15V DC for preamp, loop or reverb.
And they do not NEED to be NP, a couple standard/polarized 22uF x 50V will be very happy there, connected with the negative terminal towards the D113/114 anodes, or D109/110 cathodes.
Positive terminals towards the transformer windings .
Donīt think they will suffer more than any other voltage doubler circuit and film caps, although "better" are probably wonīt fit anyway.
2 x 22uF caps in a film version wonīt be small or cheap, thatīs for sure , and probably wonīt even fit.Juan Manuel Fahey
