Early Peavey TNT100 bass amp with no output on the speaker output jack. I did measure ~800 mADC on the output jack before disassembling the amp. Removed both RCA 62792 output transistors from circuit and both test good. Removed EP430 driver transistor from circuit and it tests good as well. No visible signs of trauma and every resistor I've tested tests good, so far.
Tried to apply some of the techniques found in some previous threads here for the same amp, but the schematic I have does not include any component designations (Q4, Q5, etc). That leaves me flying in the blind even more than I usually do.
The amp I have has the transformer soldered directly to the board with a single EP430 driver transistor and no other ICs (regulators?) on the single PCB board. Right now the amp is still partially disassembled in case it's recommended to shotgun all the small signal transistors (except Q1, Q2, and Q3), which I have seen recommended in previous threads.
I have attached the schematic I received from Peavey.
![Noob](https://music-electronics-forum.com/core/images/smilies/icon_noob.gif)
