Hello! I have some background in electronics and am taking proper precautions to work inside an amp with this much wattage but need some help tracking down the problem I'm having. My JCM800 2203 has started blowing the T2A mains fuse when running at 8ohms into an 8ohm Carvin BR12 speaker. It happens after 15-20 minutes of playing at loud volumes.
I've checked the 6550 tubes with my tube tester - all read strong and didn't come up with any shorts. I didn't see any red-plating either while watching them. Also tapped them with a chopstick and didn't hear any "chunk" or see any weird arcing inside the glass. I checked the grid screen resistors and all read just under 1k Ohms. None read open.
The amp IS noisy -- kind of a static-y background idle hum. The bass is also rather weak. I borrowed a buddy's Anatek ESR meter and checked the five 50uf/50uf 500v filter caps.
1st Can (furthest from group of four)
Red .39
Yellow .43
The rest of these capacitors appear to be wired in series.
2nd Can
Red .22
Yellow .21
3rd Can
Red .21
Yellow .23
4th Can
Red .30
Yellow .31
5th Can
Red .19
Yellow .20
The filter caps don't have any signs of leaking or pimpling but they are pushing 30 years if not more as they appear to be original to the amp.
I would appreciate helpful suggestions or ideas. Thank you!
Red .39
Yellow .43
2nd Can
Red .22
Yellow .21
3rd Can
Red .21
Yellow .23
4th Can
Red .30
Yellow .31
5th Can
Red .19
Yellow .20
