I have just built a Two Stroke amp with 8" an 10" speakers. Switch on, valves light up. No sound, no hum. I have found another thread here with a similar problem, am reading through it now. Any ideas/help much appreciated.
Duf Two Stroke amp
Hunter Two Stoke
Here is a layout diagram that I found.
Here is a link where the OP lists a few voltages that may help.
Link: NOS GE 6V6GT Plate Voltage in my SE homebrew is 425v... too high? - The Gear PageAttached Files
No hum suggests your 6V6 isn't conducting, or the output is open circuit. After checking the solder joints it could be;
Miswired
No plate voltage
No screen voltage
Missing cathode connection
Incorrect cathode resistor value.
Is there any HT output from the rectifier? Tubes lighting up just means your 6.3v is present. You need to check the voltage with a multimeter, then check each pin of the output tube base measured to ground and post back the results. Take care not to short anything with your meter probe.
Where you sent a schematic?
That Layout Drawing is a friggin nightmare to follow.
You will need to take a few static (no signal applied) voltage readings.(referenced to ground)
V1: pins 1 & 3/ 6 & 8 (Plate & Cathode)
V2: Pins 2 & 7 (Heaters)
Pins 3 & 4 (B+ & Screen)
Pin 8 (Cathode)
V4: Pin 8 B+
Yes that worked. The first thing I noticed is the impedance switch. Any issues there and the speaker becomes disconnected.
Post the voltages JazzP mentioned, also the supply voltages marked on the schematic as A, B, and C.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
