Originally posted by Daver
View Post
Odd Distortion Noise
OK, I took some time of from this thing for the holidays, other projects and to clear my head. The PI outputs are very symmetrical up until they start clipping, of course. The background overdrive sound is still there. Even if I just lightly play the strings with the amp on "2" you can hear it. I'm starting to wonder if it wasn't always there to some extent and I and the owner never really focused on it. I don't know where to look. I've ruled out a ton of things. I'm getting tunnel vision or tunnel hearing. Any other thoughts?
Originally posted by überfuzz View PostIs the 300 V stock? Seems a bit low for 6L6..?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Can you get the bad sound with a sine wave? Then post a picture of the scope display?
Maybe someone will recognize something.
Or if the signal can be eliminated as the source, that leaves the speaker, cab, or sympathetic vibrations/rattles etc.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
The distortion doesn't show up on the scope anywhere through the circuit with a sine wave. I've even scoped it with a guitar plugged in. I've already tried several different speaker cabs. All I know for sure is that it's created in the power tubes and is always there at any signal level. The OT has been replaced too. Thanks!
Ok, I re-read and saw where you used a signal tracer and did not hear the problem at power tube grids but it was on the plates.
Can you hear the problem with sine wave, or only with guitar?
In case this will give anyone any ideas, this is supposed to be a class A amp, thus the high idle current and lack of B+ drop when pushing signal.
Would the fact that the original 6L6's were 18W tubes have any bearing with regard to class A as far as using 30W 6L6's goes?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I never tried listening to the sine wave. Painful!I'm not sure it would show itself. When playing the guitar the distortion is kind of in the background and most easily heard when a note or chord is played and you let it sustain. As the original sound begins to fade the distortion is more evident. You can hear it along with the guitar as it's played but not as easily as when the sound trail off a bit. Thanks.
