Fender Frontman 15G guitar amp. Initially suffered from blown output transistor.
Replaced that and I think a diode (it's been a while). The output was very low though after that repair.
After studying the schematic a while, i figured i could make the troubleshooting a little easier, as it seems the signal either goes through U1 on "clean" or U2 on the "drive" channel, before hitting U3 and then the power stage.
So, I realize that it's super loud on the "drive" channel, even on lower gain settings, than the clean channel can attain wide open.
From that, I surmise that I can essentially ignore U2, U3 and the power amp portion of the amp, focusing primarily on U1. I checked input signal to verify 5mV, checked and found +/- 15V on U1, but only about half the output at pins 1 & 7 of U1. I do remember checking all resistors around the U1B section of the opamp, but not necessarily around the A portion of U1.
Even so, is it fair to say i should replace U1, or are more tests needed?
Thanks
Thanks
