Originally posted by Tom Phillips
View Post
Fender HR Deville Had a Drink.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I think Tom was referencing this case in particular where the burn is between traces and no connections need to be rebuilt. I'm ok with just leaving the hole. If you need to rebuild some connections, the corona dope is certainly a good idea. I don't see it as necessary in this case. So there, you "old resentful repairman"."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Tom beat me to it, I see no reason to fill the hole, air is a better insulator than the other stuff. In fact in some pc board power tube socket areas they actuall make small slots in the board on either side of pin 3 to help prevent arcs. CRT video monitors are sometimes made the same way. I have also seen slots cut in the circuit boards of SMPS for the same reason.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostTom beat me to it, I see no reason to fill the hole, air is a better insulator than the other stuff. In fact in some pc board power tube socket areas they actuall make small slots in the board on either side of pin 3 to help prevent arcs. CRT video monitors are sometimes made the same way. I have also seen slots cut in the circuit boards of SMPS for the same reason.
I have a bottle of corona dope I bought back in the 1970s. I never used even half of it. Exactly when it dried up into a solid red lump in a jar I do not know.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostI have a bottle of corona dope I bought back in the 1970s. I never used even half of it. Exactly when it dried up into a solid red lump in a jar I do not know.
Yes. It will now be no more likely to strike an arc than it was in the original instance where it struck an arc.
So what does one do in cases such as newer boogies where the traces are just too close together and arcing is not uncommon? Shave the traces? Re-design a board?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View Post...So what does one do in cases such as newer boogies where the traces are just too close together and arcing is not uncommon? Shave the traces? Re-design a board?
Edit: The practical approach for the Boogies that are prone to arcing is to keep the internals really clean. Same goes for tube sockets. Especially if someone has used an inappropriate cleaner or contact spay that left a residue that then starts to collect dustLast edited by Tom Phillips; 04-18-2015, 07:34 PM.
Originally posted by g1 View PostYes. It will now be no more likely to strike an arc than it was in the original instance where it struck an arc.
Oh... Here's a thought. One could just cut out the HV pin and cut through the trace an inch above. Then hardwire only the HV."Take two placebos, works twice as well." Enzo
