From the symptoms described, it is highly unlikely that the transformer is bad. From the description of the tech, his diagnoses are very questionable.
So I think 52Bill just mentioned that in the unlikely scenario that you end up needing one.
But here's an idea. If you were to buy one of these and supply it to the tech, under the agreement that if it did not fix the problem, you get the amp back for the minimum bench fee (estimate charge).
