Hi,
I have this amp in for a couple things, one there was no sound and the amp in and out jack's threaded shafts had been broken off.
The no sound issue was straight forward, a shattered V1. Replaced the 2 in and out jacks.
Now I;m finding that the reverb isn't working, and I can't help but think it's something that I'm may have done.
This particular amp has been repaired a bunch of times. So much so that the main board flops out and is pretty loose compared
to other amps of the kind. So as a result after finishing the jacks I find that 2 of the ribbon cable are having some serious problems
so I cut them out and wire them up with individual wires.
Anyway, I've checked quite a few things here and swapped out components to no avail, no reverb.
Parts swapped Q2 and U2 and the tank. The cables are good, they have continuity to the tank in the right ways, I believe.
Now I need some help.
Could changing the power amp in jack have any effect on the reverb working or not?
Any suggestions on where to proceed?
thanks
pete
thanks
pete
