I picked up a 1484 for my next project. It amplifies the guitar signal well, but it is also generating noise that seems independent of the guitar signal.
The noise sounds like crackling, wind, etc and varies on its own in intensity and volume. It can start to build in volume so loud, to the point where I have to flick the standby switch to stop it. It is present even with both volume knobs set to zero. My hunch would be capacitor issues. The capacitors in there look like a mix of original and replacements. I have attached some pics.
I know this is likely a common issue but I have little experience with working on these issues. Looking for recommendations on how to approach this.
When I first got the amp I went through the whole thing, tested all tubes, cleaned all connections. Tested the amp and did not hear any noise. I then repaired the jewel light holder (no continuity on center pin, I soldered a jumper wire) and installed an output jack. Now I have the noise. I can't imagine my repairs would have anything to do with the noise.
Thank you! Mark
Thank you! Mark
