Marshall VS65
  • Marshall VS65
    I have this amp that was dropped off and it is extremely low and very distorted....When scoping the reverb send RCA jack the signal is nice and clean with lots of amplitude......Checked the line out, send and return jacks and the signal is very low and distorted....I had these jacks hooked up to an external amp....I measured some voltages and the power amp voltages are plus and minus 40 volts and the low voltage is plus and minus 15 volts...so that appears to be ok....I did notice that when checking the op amps for individual voltages, IC6 has the following voltages...
    (PIN 1 -14.82V) (PIN 2 0V) (PIN 3 0V) (PIN 4 -15.04V) (PIN 5 -14.87V) (PIN 6 0V) (PIN 7 +15.15V) (PIN 8 0V) The schematic copy that I have is not clear and when you try to enlarge it, it becomes very badly distorted...any chance somebody here has a clearer copy?? As for these voltages, they don't seem right to me....I also noticed that when turning the amp on and off you get a loud thump in the speaker so the mute ckt isn't working.....but that I can tend to later...first I want to get the distorted sound straightened away.....
    Cheers
    These pages from Dr.Tube seem a bit clearer than the pdf from elektrotanya.
    http://www.drtube.com/schematics/mar...65-60-02-1.gif
    http://www.drtube.com/schematics/mar...65-60-02-2.gif
    http://www.drtube.com/schematics/mar...vs65-61-02.gif
      Ok. I'll print them off and blow them up on the copier....11x17.....to see if they are any better.....The eyesight is not as good as it once was....
      Thanks very much.....
      Cheers
        When I look at those pages online, the mouse cursor becomes a magnifier button. Clicking that makes it fairly clear.
          Yeah I know.....I still don't find these all that clear.....I always use paper copies...for a couple of different reasons.....easier to carry, can make notes on them, can color code supply, signal lines, etc....and the filing cabinet doesn't crash on me....I'll blow them up and see what they turn out like....Thanks for the links.....
          Cheers
          P.S. Don't those IC chip voltages seem odd to you??
            Not sure about pins 1&5 (offset null), but the others seem right.
