Hello all,
I have a small Peavey Blazer 158 amp that I use for practicing. Got it used. When I turn it up (up a little bit, but not to huge clipping type levels), its output is a little fuzzy/distorted. Sounds just like a fried IC.
Right next to this amp is sitting basically the exact same amp (a Peavey Rage 158), basically same thing except it does not have reverb. It is not blown, and sounds great, nice and clean, so I have a good reference to compare the Blazer to. The Blazer cannot be turned up even half as loud with the distortion getting pretty heavy. So I am near 100% certain that the amp was just turned up too loud and the IC overheated. Have had this problem on other small wattage amps before and have replaced the ICs and fixed the problem every time.
The IC in this amp is a TDA 2040. I ordered 5 of them in a pack.
When I replaced the old IC just today with a new one, no sound. Nothing. No pops, no hiss, nothing whatsover from the speaker.
I put the old original one back in, just to see if I had accidentally bumped something else. Amp worked just as before (full sound, with the distortion of course).
Took the original back out, put in a second IC (not the first one I tried), thinking maybe the first one was bad. Nothing. Again.
Something is obviously up with the IC's that I have. They must not be the correct ones. Am I missing something?
The original IC says: TDA 2040 ; 80A905; SING . The replacements say TDA 2040 ; 82H411 ; SING
Any ideas why the replacements would not work?
Thanks in advance!
Thanks in advance!
