Hi folks,
So I'm new to this forum, but have been looking around any forum I can find that has information on Fender Blues Juniors and tube amps in general, and this one seems to be one of the best. I'm hoping someone here can help guide me in some PD on a second hand BJ (cream board) amp I got a few months back. I love the sounds I can get from this little amp, but from the day I got it, I noticed a quietish but still annoying, persistent slightly buzzy hum. I've read enough forum posts to know there are plenty of people with BJs that hum, and describing the hum and knowing if it's 'normal' or excessive, is half the problem. I checked against a new BJ III in a local shop, and it was dead quiet compared to mine, so I don't think I'm just being picky and think this one does have a problem.
Anyway, I'm hoping someone here can help me in some problem determination, and can at least tell me if I am being too picky and what I think is hum is normal for one of these. I dabbled in electronics and have built bread board circuits from designs (even built my own effects pedal a loooooong time ago), but I'm no expert. I like a bit of a challenge, but I don't want to spend more than it would cost to buy a new BJ III trying to fix this one.
First the obvious and my PD so far: The amp is pretty silent, except for a very quiet hum from the PT, until it warms up and then the hum with a bit of buzz is heard from the speaker. This is with nothing plugged into the input jack and all controls at zero. I've tried the amp in different rooms to discount any local EMF from other equipment and the hum is the same wherever it's plugged in.
The hum doesn't change when any of the controls are adjusted - but it does start to hiss when vol and master are wound up (as I'd expect) and that does have a bit of an effect on the hum, but it's marginal.
I have replaced all the tubes with new JJs including matched power tubes (bought from a tube specialist on-line) and tried swapping the pre amp (V1, V2) and PI (V3) tubes around - with no change to the hum. I've pulled V1 then V2 and there's still no change - pulling V3 and it does go quiet, but again - as expected.
I even sent the amp to a local amp tech and got him to replace the Power cap (and upgrade from 47uF to 100uF to tighten the sound a little) and the three filter caps with new good quality caps - and to try and fix the hum/buzz but he couldn't find the cause. He also reflowed the solder joints on the tube connections to the PCB. All lovely, buit no change to the hum. Though the bass does sound better, at least
In an attempt to work out if it's 50Hz or 100Hz hum I'm hearing (I live in the UK), and because reading a few other sites it seems an oscilloscope is pretty much mandatory for really understanding your amp, I got a handy, but basic little digital oscilloscope (eBay is my friend) called a DSO Nano for £30 so I could check the signal in the amp itself.
Connecting the scope to the speaker blue terminal and ground (the amp chassis) I get a very clear picture of 50Hz hum, with a bit of distortion which pretty much matches the sound I'm hearing - a buzzy hum. According to the scope, this hum 'signal' is 8.37mV vrms - Vmax is 11.8mV and Vmin is -14.7mV. Is this reasonable? Am I being picky?
See picture below:
So - I've confirmed it's 50Hz, which is great, but what do I do about fixing it? What else can I check? Any hints on where in the amp this hum could be coming from based on the info I've given, or suggestions on where to look would be much appreciated.
I have tried Bill Machrone's suggestion of putting a sheet metal shield between the PT and OT to try and divert any leaked magnetic field from the PT from entering the OT, but that didn't make any difference.
(PS The scope is useful but it is limited - it only has DC coupling, so reading AC signals with high DC is tricky as I have to set the probe attenuation to 10x and the scope to match and then I can't easily read small AC on top of the 300+Vdc that is inside this amp in some sections. That said, I did manage to identify and fix oscillation in the circuit that matched what Bill Machrone describes as PI oscillation. I found a 41kHz signal at the input to the OT transformer and fixed it by putting a 100pF cap across the R30 resistor. Worked a treat. But still didn't fix the damned hum!)
Many thanks in advance
Si
See picture below:
Si
