Originally posted by LondonSi72
View Post
Since you get hum with the master at zero it narrows the problem down to the trace from R22 thru W10 and then C11 to pin 7. Try putting your 100nF cap from the end of R22 that connects to C11 to ground and see if the hum goes away. If that does then then try from the other end of R22 ( since the master is at zero.
