Guys, I have a 40th anniversary JTM 45/100 Super 100 with a noise issue. Pro customer says it's unusable. It voltages run hot on these, so he uses a bucking transformer I built for him last year. Problem is this, with both volumes down, there is a noticeable low frequency hum and a higher buzz. Raising the normal channel increases the hum, and raising the bright channel raises the buzz. This is the case even with the first pre tube removed. I have checked all the grounds, and re-flowed all the turrets for good measure. It does it with either the outside or inside pair of KT66s removed, albeit at lesser volume. It also does it with all pre tubes removed, except the volumes and tone pots have no effect. I've tried jumpering in a fresh electrolytic at the PS filter caps to no avail. I request help on how to think about this one.
http://www.soultoneamps.com/images/JTM45100.jpg
http://forum.metropoulos.net/download/file.php?id=4349
