Ampeg filter cap question
  • Ampeg filter cap question
    I have 70's era Ampeg solid state amp in (can't even tell what model) that needs filter caps. And maybe more, but first things first. The values are 2500uF/90v. Being that it is an odd value, I'm having a hard time finding them at a reasonable price. I wonder who among us would have a problem replacing them with 2200uF/100v that I find at Mouser for about $5/ea?
    I wouldn't have the slightest problem doing that. The value difference is roughly 10%, and caps are usually less close than that anyway.
      No problem at all Randall. Heck I might go up a notch or two in the capacitance rating. Most amps were designed with absolute minimum cap values, to save $$ in manufacturing and maximize profits. "So what if it hums, those electric guitar players are so loud they'll drown it out." You have the choice & opportunity to improve on a just-barely-good-enough design.
        Ampeg BT-15 (fliptop) with the electroluminescent display?
        Schematics are usually on the inside of the chassis cover. I have replaced the PS filter and the output caps with radial aluminum electrolytics from digikey - so you're on the right track with 2200uF/100V.
