Ampeg B25 Chassis Mounts?
    McMaster-Carr has them a little cheaper with choice of rubber (9376K17) or neoprene (9213K12).
    https://www.mcmaster.com/#vibration-...ounts/=15qann9
      There is a lot of stuff on eBay for close to $1 for each piece. Need to determine the right size.
      Right now my best guess on the original size of the mount is 17 mm wide x 10 or 11 mm high. Bolt studs extend about 10 mm in each direction.
      If I find something shorter in height I can compensate on the new mounting blocks.
      Going to start another thread as I also have electrical questions.
        Originally posted by Leo_Gnardo View Post
        https://www.grainger.com/product/GRAINGER-APPROVED-Vibration-Isolator-2NNZ6?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/2NNZ9_AS01?$smthumb$
        Those look like a good contender!
          A quick application of the old wooden school ruler showed me 1/2 inch high on the rubber cylinder by 1/2 inch wide. I s'pose 5/8 wide on the Grainger or McMaster part is close enough for rock n roll.
          Don't forget, the side of the mount that fits the end-blocks, has to have a mating threaded slug in the wood. Next let's find some of those. Whoever has 'em both, reasonably priced, wins our business.
            Hoping to re-use the old ones. Should be able to tap those out. Will give all that a shot when I get some scrap wood to make the blocks.
