i have a silverface Fender Vibrochamp that was a project amp for someone before i bought it on ebay. they didnt know what they were doing, or encountered a problem they didnt know how to fix, and sold it as-is. the only thing is, i didnt know that when i bought it. they had stuck a piece of wire in the fuse holder to keep it running. i didnt know that either, until it just quit on me one day. the rectifier was glowing red hot, and crackling from the heat! i was sure i killed it, so i just let it sit in a corner for over a year.
then about a week ago, i got tired of looking at it and decided to do something about it. to make a long story short, the power tube socket was the culprit for it blowing fuses. it phelonic (sp?) material went bad, and was arching between the pins, and going to ground through the power transformer.
so i replaced both the power and recitifier sockets with ceramics. no more blowing fuses. so the amp "works" but then it had a nasty crackling sound whenever i played anything on the low E string. i read up on capacitors and decided to replace them all. i did that last night with good results, BUT the crackle isnt totaly gone. its still there, but nowhere near as bad as it was. i also seem to be getting a weird subtle oscilation on some notes, and a staticy type of noise on other notes. compared to it blowing fuses and being completely dead, this is a huge improvement, but i can tell it aint right.
i have everything i need to replace every component on the board, and im tempted to strip it all off, clean it up, and replace everything, leaving only the Filter Caps, and the transformers as original parts (assuming theyre original).
im -obviously- new to the whole tube amp thing, and im resigned to this amp being a project amp. something i can tinker with, and hopefull learn something from. im not the type to just turn a knob and be satisfied it works. i want to know what goes on behind the knob. ive been reading up on tube amps, and i have a very basic grasp of how they work, but barely.
my question is this: i know the filter caps supply very high voltage to the board. i know to drain them before working on the amp, as getting shocked can kill you. when the amp is running, tubes are in, speaker hooked up, i get voltages up over 400vdc. but when i shut the amp off, the voltages drop to 25, and then 10 within 30 seconds of shutting it down. -are the caps bad? shouldnt they be holding that voltage alot longer? or do i still have a problem elsewhere? how do you know when the filter caps are bad?
-also, ive seen replacement filter caps online -supposedly direct replacement for champs and vibrochamps- saying 20-20-20-20@475v -ive only got 3 leads comming out of the filter cap can. so that doesnt seem right to me.
can i take off the can, open it up and just swap out the caps inside?? -with the correct values of course... it'd save me money...
i hope someone can help. im told these are VERY simple circuits, and perfect for someone to learn about tube amps. i just need a place to start, and pointed in the right direction.
thanx
jim
thanx
jim
