Can you solder parts on a circuit board? Can you identify the parts? Can you look at a schematic and identify which ones there are the real parts in the amp? Do you have and can use a meter?
Most common reason for an SS amp to blow fuses is shorted output transistors.
I can solder. I'm not 100% on schematics but there's always google. I know how to check continuity with a meter and output on a pickup but that's about it.
Is the output transistor the little thing that looks like a black hat?
