I found an early DR (serial in the 200s) that doesn't work for fairly short money. I figured it'd be an easy flip since I found a previous non-working amp (serial in the 400s) last month and made some quick profit on it.
The problem with this amp is the same as the previous one - power tube arced between pins 2 and 3. In the previous amp, this destroyed the 100-ohm and 150-ohm ground reference resistors in the 6VAC supply. For some reason Mesa used carbon comps here..the ONLY place they used them - and they went up in flames. Fortunately there wasn't any collateral damage, and new resistors and removal of the carbon trace did the trick.
This amp is tougher - the 100-ohm resistors were OK but the 150s did a full burn, and I had to grind out about a 3/8" hole in the board. I got new components mounted (it also took out one of the rectified 6V filter caps and blew a transistor apart), and connected the broken traces under the board, and it fires up and holds steady. BUT, there's hum in the preamp (sounds like 120Hz pre-gain and 60Hz pre-master) and very little gain.
Going into the loop return, it works fine. But it seems as though at least some of the LDRs aren't working in the switching circuit. The 5W 220-ohm resistor that precedes the diode in the 50VAC-to-9VDC supply has about 18VDC and about 25VAC on the diode side and gets REALLY hot; the following 100-ohm (68 ohm on the Schematic Heaven schem) drops another 10V or so and runs cool. There's about 8VDC in this rail, which seems a little low.
I swapped the 6N193 LDR/Darlington, no joy.
Voltages on Q1-Q3 look OK.
What should I be doing next?
