I have rebuilt a non working '59 bassman reissue that had a couple of dubious mods, broken wires and loose solder joints. Since it was in bad shape i ripped out everything and converted it to a point to point amp. Everything is looking fine but I get no voltage on the secondary side. I switsched it on with only the rectifyer installed. Between the white and black/red wires (230V tap) I get the 230 volts AC so the fuse and switch are ok. Across the red wires on the rectifyer I get 0 volts.
The wiring looks ok ... red/yellow is wired to ground, the rectifyer is wired correctly, red/blue is connected to the bias circuit and the unused power taps are isolated off. Could there be any other explaination for this than a defective power tranny? I just want to make sure before i order a new one
thanks!
thanks!
