Hi, After a quick solution to an issue I've got.
Just tried to use the Line Out on my Silverface Pro Reverb Ultralinear for the first time ever as I need it for recording this weekend only to find it didn't work. Pulled the chassis and the circuit doesn't match up with the schematic as the pull boost circuit has been removed. There are other obvious mods in there making it a real headfudge. Can anyone offer advice as to what has happened?
I basically just need the line out to function correctly again so if anyone know a quick reqiring fix to get a line out signal to that jack then I'm all ears.
Below is the scheme and a quick sketch of how the amp is now. Theres an additional 470K resistor and some value changes after it. Line out jack no longer seems to go to the master volume.
