Does anyone have any photographs of the underside of the power tube circuit board, showing the resistors r16 and r17? I have had them blow, and the outside markings have been burned so I can't tell which type they are, I know they are 100s from the circuit board, but further than that I can't tell and need to replace them. Any help would be greatly appreciated.
bugera 333xl head
Then you already know, they are 100 ohm resistors. They form the virtual center tap like on a zillion Fender heater strings. Since they burnt up, I'd replace C6 as well. 100uf 25v.
100 ohms, shouldn't need much wattage. I'd replace them by size, so do they look like half watt, one watt?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThen you already know, they are 100 ohm resistors. They form the virtual center tap like on a zillion Fender heater strings. Since they burnt up, I'd replace C6 as well. 100uf 25v.
