Neat tool to avoid slipping probes damaging other things
  • Neat tool to avoid slipping probes damaging other things
    Found this in a lot of Electronic misc items. It came from Radio Shack It fits on the end of a meter probe. I wish I'd had this in the past when probing solid state stuff.
    nosaj
ID:	871784Click image for larger version
    It also pays to use needle sharp probe tips, yes the kind that poke into your skin all the time. Most probes are just cone shaped on the point but not sharp. Sharp probes pierce the lead solder and make good contact and don't slip off as easily.
      I've often just slipped some heat shrink onto the probes, leaving only the tips exposed after shrinking.
        We have some at work but I usually have different probes for different jobs, sharpened and covered in heat shrink as Enzo and RG mentioned.
        Also chip clips that fit over a chip with metal pins sticking up to clamp scope probes on for monitoring as many points as scope channels you have.
        I have a couple 4 channel scopes and a digital scope at work.
          There are now probes available that have a retractable shroud that you can extend along the tip and decide for yourself how much of the tip remains exposed. The Fluke TI175 probe is an example. The heat shrink trick is what I use but these new probes looked kind of neat.
            I really appreciate the tips that come up when something is posted. It is so great to have a Collective mind here.
            nosaj
              Originally posted by Tom Phillips View Post
              There are now probes available that have a retractable shroud that you can extend along the tip and decide for yourself how much of the tip remains exposed. The Cluke TI175 probe is an example. The heat shrink trick is what I use but these new probes looked kind of neet.
              Hey, they look pretty nice.
              http://www.mouser.com/images/microsi...20Features.jpg
