Hammond 1750p for jcm 2000 50w
  • Hammond 1750p for jcm 2000 50w
    The tech department at hammond said the 1750p ot is for the jcm 900 but would work for the jcm 2000 50w. Any advice?
    Marshall used their TXOP-00002 in both those amps, so yes it will work.
    The classictone replacement is also spec'd for both those models:
    50W / 60W Marshall JCM900 & JCM2000 Style Upgrade / General Replacement Output Transformer, 4/8/16 Ohms, 784-348
      Awesome thanks for the help
        Looking at the spec sheet
        https://www.hammfg.com/files/parts/pdf/1750P.pdf
        It's got a 3k4 primary and 2/4/8/16 secondaries and is rated for 50W. All those numbers look dead-on for that application.
        that multi-tap secondary is a nice feature. you don't see many that have both 2R and 16R taps. it would make a good "universal" OT.
          Does anyone know which color wires go to which terminals?
            Aren't they labeled ? , according to the jcm2000/dsl50 schematic W3 & W4 go to the power tube plates & W5 is the center tap
            "UP here in the Canada we shoot things we don't understand"
