Hello folks, I have a 1974 Super Reverb here for which I am attaching a schematic and a few pics pertaining to my issue. So this amp obviously has had the output transformer replaced. It's kind of funny looking, but hey, I ain't prejudiced. The specified impedance (3800) for the primary looks about right. The wiring for the secondary is where I'm having trouble. There are 4 wires, black, green, white, and yellow. The label indicates there is a 4 ohm tap and a 16 ohm tap. The similar OT at this link http://www.hammondmfg.com/pdf/EDB1760K.pdf also has 4 wires, but black is common and the other 3 are for 8, 4, and 2 ohm taps. Unfortunately I couldn't find any helpful information regarding the installed OT, but at 1st glance I assumed the installer meant to have one of the speaker jacks wired for a 4 ohm load and the other for a 16 ohm load (I do realize this is strange since a SR typically has a 2 ohm load). But even if that were the case, I'm not knowledgeable enough to know whether the wiring is in fact correct for that objective (in any case, it doesn't look right to me) or to know how it should be for certain. As shown in the photo, the black and green wires are connected to the the tip lug of the main jack and the white and yellow wires are connected to the sleeve lug of the other jack. Absent proper documentation, is there a way to figure out the respective purposes of each of the four wires using my DMM? Any insight at all is appreciated.
EDIT: In case anybody was wondering, there are no speakers currently installed in the amp, so no help there in determining what the intention was of the tech who put the OT in.
- BL
cbs_45w_mstrvol_pullsw_super-pro-bmstr_rev.pdf
![Click image for larger version
- BL
