Originally posted by Valvehead
View Post
Bias problems---
Originally posted by Enzo View PostStart looking for conductivity or foreign material on the board in that area. Also look for a tip of a component lead nearby touching that trace. If so, trim it back. Follow the trace from pin 2 to anywhere it goes, looking for anything along the sides of that trace somehow touching it.
So with C45 removed, you still had 230V at the grids of V6 & 7 ?
But with R78 & R79 lifted it disappeared?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Sounds like maybe board leakage, not sure from where.
You still have the EL84's out?
Earlier you said 280V at the grids, now it is 230V?
Point C is 290V? How about pin1 and 6 of PI tube?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
After you report back with the voltages g1 was asking about, I want you to try something..
Pull the Phase Inverter tube, solder r76 and r78 back in circuit, and power back on. What's the voltage at the grids now?If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by g1 View PostSounds like maybe board leakage, not sure from where.
el84s out , PI in , all resistors / caps in
v6 220v
v7 220v
v8 0v
v9 ov
point C 355vdc
PI tube pin 1 353v
pin 6 354vLast edited by Valvehead; 04-01-2018, 10:52 PM.
Originally posted by SoulFetish View PostAfter you report back with the voltages g1 was asking about, I want you to try something..
v6 258v
v7 258v
v8 0v
v9 0v
Originally posted by SoulFetish View PostOkay.
When you power up are those voltages present on the grids immediately or do they climb to those voltages after some time?
Ok... i just got back from vacation last night. Ready for the madness ? I powered it up to test just now .... and now I have 15 vdc at the grids of V6-7 and 0vdc at v8-9................yep !
Are there any signs that something might have been spilled in the amp? I wonder if there was moisture somewhere that has dried out- maybe under a socket or something? I might hit the board with some compressed air and/or hair dryer. That, and a thorough inspection."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
