Originally posted by dstrat
View Post
Pro Reverb Voltages
Originally posted by bobloblaws View Post...how I would use the scope to check for oscillation, say in the context of this discussion?
To identify free running oscillation, firstly it's easiest to listen for it, but if ultrasonic, just twiddle / sweep the 'volts/div' and 'time/div' controls with the amp idling, whilst checking for anything more than its regular noise floor becoming apparent on its output.
Parasitic oscillation requires a signal for it to manifest (ie the amp should be mostly stable at idle), the scope shots in Chuck's search show examples.
Bear in mind that an amp's margin of stability may differ according to its load; an amp may be stable with a resistive bench load, but instability may manifest with inductive loads such as a speaker.My band:- http://www.youtube.com/user/RedwingBand
