Behringer p2502 poweramp module
  • Behringer p2502 poweramp module
    Got a Behringer Pa with p2502 poweramp module can't quite figure out how to insert the pdf into the forum so I have a screenshot of the section I have a question about.
    There are some burst caps c31 c32 c36 c37. 220uf 50v
    Can I use 470uf 50 and still be ok?
    nosajClick image for larger version
    Thatīs a voltage multiplier to get +48V phantom for the active microphones.
    Guess you might double capacitance but why?n 220uF x 50V is a very common easy to get value, so just use bthem.
    You will NOT improve ripple or whatever since actual 48V are regulated by T17 and associated 47V Zener D53
      i was looking at what I had on hand is why I asked.
      Thanks,
      nosaj
