Hey folks. Apparently I'm not educated on exactly how to tell what tubes can be used in specific amps. I was under the impression that if it could handle the plate volts you could use it. I was just told that the el34s I just put in my JTM45 Marshall build don't match the OT primary resistance ,but was told I could use the 16 ohm tap on my amp with the 8 ohm cab ,and that would give the tubes what they are looking for? I was using KT77s before that ,and they seemed to work ok. I removed those because they are part of a quad I sold with a MusicMan amp. I just thought most Marshalls used el34s. Can someone please shed some light on this?
It started with me replacing these tubes ,and some dropping resistors because I was thinking the voltage was too high. The amp has no noise ,but doesn't sound very good in general. Sounded way better with the KT77s. Along with changing these dropping resistors I changed some others where I had installed metal film ,and metal oxide. (it's all I had when I was building it) I also replaced the preamp tubes with some vintage Amperex. I was thinking this may have some to do with the tone as well. Maybe just one is bad ? I'm planning on putting the dropping resistors back ,and trying the newer preamp tubes to see what she does.
I'm attaching the specs for the OT I am using. Thanks folks.
