Peavey XR684 schematic.zip
Hi all, I have one of these on my bench at the moment, here's a fun story for you.
It wasn't powering up fully, no lights on the front preamp, but the fan was spinning and the fuses were good. I found it had a dead +15v regulator, I read elsewhere on the forum that this isn't uncommon. I swapped it out and everything lit up like christmas, excellent I thought. The power output was there now, but low. I figured I could plug in directly to the power amp input and bypass the preamp to test, so I plugged my phones 3.5mm output with a tone generator app running and sure enough I had a strong output on the power amp. I swapped the jack over to the Right PA input, the phone turned off, something fizzed and the preamp rebooted.
Now my android phone has a blown headphone output, it's royally screwed, the Right PA IN was actually putting out +15vdc On a closer look CR1313 is dead short, which probably explains why the voltage regulator went bang in the first place.
I learnt a valuable lesson today on not using my nice android phone as a tone generator on old broken amps.
