Greetings. I am about to start on a Tweed Tone 20 amp, a Chinese made amp that looks very similar to a Blues Jr, but I think it may sound a bit better courtesy of its Celestion speaker. Like the BJr, the main PCB is mounted vertically. When I looked at the main filter caps there was this solidified purply-black coloured hard stuff that was flowing down the PCB from the caps. Have you ever seen anything like this? Is it just sloppy gluing at the factory ... or capacitor guts that have oozed out of the bottom of these radial caps.
Capacitor Guts or Glue?
And just for the future, you'll know if it's cap guts. They stink to high heaven if they're fresh. And if not, it's usually seen as a light-colored powder or crust that gets left behind when the electrolyte dries away. If they explode there'll be bits or rolls of aluminum foil in the immediate vicinity.
And yeah, I'd hesitate to use anything colored black on a circuit board... I'm with Mr. Bass on the "clean up what you can" thing.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
It’s weird for the gloop used to mechanically secure parts to the board to be 2 tone.My band:- http://www.youtube.com/user/RedwingBand
There’s a light blue MF style resistor, may be 2W, between R19 and R49; the gloop is clear at one end if it, dark at the other?
And it’s dark around the tab connector (red wire, upper right of board).My band:- http://www.youtube.com/user/RedwingBand
Hot melt glue gun that was reaching the end of one stick and had a different colour stick put in for reload?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I look at it and I see a dark smokey color goop, that in thin spots is translucent. Doesn't look like different colors, to me, anyway.Education is what you're left with after you have forgotten what you have learned.
