I have a signal on the headphone jack and at pin 10 of the LM3876. No output at pin 3 of LM3876.
LM3876 pin 1 has +27V, pin 4 should have -27V but there is nothing there.
I have -27 VDC at C64 and D27. C64 and D27 have continuity. Neither has continuity to LM3876 pin 4.
Neither C64, D27 or LM3876 pin 4 has continuity to chassis ground.
I cannot get a probe on C49 and have not pulled the board out yet. Suggestions? Would a bad C49 cause this problem?
Thank you!
I am attaching Champion 30 schematic which appears identical.
Thank you!
