Originally posted by boroman
View Post
Ampeg V4 wierd channel 1 & 2 interacting
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I give up..
I have changed two jacks as both of them were not shorting to ground when the instrument jack was released. I also changed one of the resistors which measured a little higher (7.5Mohm vs 5,6mohm). Having a bit of time, I also replaced diodes and added bias pot...
And I'm in the beginning. The same behaviour like in the first post. I don't get it. I have tried to measure all the caps and resistors near V1/V2 and all looks/measures close to its specs. No bad traces, no overlapping solder joints. I have got some photos of previous work on other V4's and it PCB/wiring looks the same. I have no idea what to do now. Maybe it'll be "spare parts" V4 for some new projects.
OKAY,
One more thing which I do not underrstand. In the attachment photo there's a shot of the original jack wiring. All of the lugs are shorted with each other, so ground is shorting with signal???
1 - solid wire jumper to 2 position
2 - negative (black) from pcb + resistor leg2
3 - positive (white) from pcb + resistor leg1
4 - tip (=2)
So from this picture everything is connected with everything. Resistor between 2 and 3, jumper wire between 1 and 2. So there's no way that we have separate ground here
Confused.
Originally posted by Helmholtz View PostYes, that's the way it's supposed to be: Everything grounded as long as no plug is inserted.
That's why I dont get it.
All lugs are connected to each other, so there will be shorting with the jack inserted and without it too. Am I missing something?
Originally posted by boroman View PostIf the plug is inserted, everything is shorted too.
All lugs are connected to each other, so there will be shorting with the jack inserted and without it too. Am I missing something?Last edited by Helmholtz; 12-12-2019, 01:32 PM.- Own Opinions Only -
And I'm in the beginning. The same behaviour like in the first post. I don't get it. I have tried to measure all the caps and resistors near V1/V2 and all looks/measures close to its specs. No bad traces, no overlapping solder joints. I have got some photos of previous work on other V4's and it PCB/wiring looks the same. I have no idea what to do now. Maybe it'll be "spare parts" V4 for some new projects.- Own Opinions Only -
Originally posted by boroman View PostAm I missing something?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
OK, let's go ahead - it's not the input jack fault. Tested it right now and all seems OK.
What should I do to disconnect Ultra Hi switch leaving it on neutral setting? Looking at the schematic it seems it passes throught C3 (0,01uf), C102 (0,00012uf) and C101 (0,001uf). I thought neutral setting on this switch was not going through any cap (at least I remember it from V4B). It seems that the mid one from these caps is C101 so this is the neutral? (the same for CH2 = C104)
For further advice, please post close-up pictures of the switch and vol board to see the physical layout. We also need to agree on a way of numbering the switch terminals.- Own Opinions Only -
Originally posted by boroman View PostI thought neutral setting on this switch was not going through any cap (at least I remember it from V4B). It seems that the mid one from these caps is C101 so this is the neutral? (the same for CH2 = C104)
(+) setting puts C102 as bright cap across volume.
Neutral setting puts C101 & C102 in series but shorts the 2 ends together. However it is still connected to the wiper so could cause interference.
(-) setting puts C101 from vol. wiper to ground.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Thank you guys.
The story goes on:
I have disassembled and cleaned Ultra Hi and Midrange switches, cleaned contacts and now I see how it works another thing learned!
Inside switches is all OK, does not look strange at all. I have raised the two "contact elements" to have better contact with the points/lugs on the switch
speaking of Ultra Hi switch these are my measurements:
Pinout:
1A - 2A - 3A - 4A
1B - 2B - 3B - 4B
When MINUS is engaged: 3A shorts with 3B / 4A shorts with 4B
When NEUTRAL is engaged: 4A shorts with 4B
When PLUS in engaged: 4A shorts with 4B
Resistance between 1A and 4A is 175k
Resistance between 1B and 4B is 850k
No sound change between NEUTRAL and PLUS (usually when volue is up and treble is fully up going from minus by neutral to plus raises buzz and noise floor. plus seems the same as neutral)
Pots fully up (but these values not change when they are turned down)
IMAGES:
Pinout:
1A - 2A - 3A - 4A
1B - 2B - 3B - 4B
In position NEUTRAL the switch shorts 2A with 3A and 2B with 3B. In position PLUS the switch shorts 1A with 2A and 1B with 2B.
As row A and row B connect to different channels, it is essential that with the switch in MINUS position there is no leakage between either 1A or 2A and 1B or 2B. Because of the path through the pots you should measure something like 2M between 1A and 1B, but infinite resistance between 1A and 2B, between 1B and 2A and between 2A and 2B.
Also in PLUS position there should be no connection/leakage between 3A and 3B.
I hope I got all this right. If the switch was completely disconnected I just could have said: Make sure that none of the row A contacts leaks to any of the row B contacts.- Own Opinions Only -
