So the idle current is actually sensed by the shared 1R cathode resistor in parallel with D27 (which is not conducting in normal operation).
What’s the secret to biasing a Blackstar ht40?
Originally posted by JZRepair View Post
Yes, I understand the procedure, but this will not properly bias the amp and is verifiable through the bias probes. PR2 controls the bias current, true. PR1 controls the balance of available current through the tubes, but actual current through the plates and voltage across the plates are what matters, not this misleading voltage across D27. This is an incredibly lazy way of biasing an amp and is going to cause a lot more tube failure. The balancing of PR1 is visibly seen with bias probes, as the balancing of current across the plates to cathodes in each tube. Adjusting the pot one way or the other simply adjusts the available current (available current being set by PR2) across the plate and cathode respectively in the output tubes, meaning the PR1 pot simply negates the need for matched tubes. Maybe I'm wrong, but it shouldn't have anything to do with distortion when a 1kHz signal is put through the amp at full volume unless you're already overbiasing the amp, which is going to shorten the life of the tubes.
50mV across a shared 1ohm cathode current sensing resistor averages to 25mA cathode current per EL34. Which seems a reasonable, conservative level.
Im not sure that the tech info has been officially published into the public domain? So it’s only intended for techs, and hence the balance setting method seems reasonable.My band:- http://www.youtube.com/user/RedwingBand
- Likes 2
Originally posted by pdf64 View Post
Having seen the schematic, I wonder if you’ve misunderstood something?
All I'm really saying is, I don't like it. I don't agree with this procedure. It may not be "public domain" but the fact it's on this forum means it's public domain and anyone can find it now. So yeah, I think there are some concerns with this procedure and I wouldn't recommend it.
And by no means am I implying I know it all. I welcome the other view points from this, because it's all a learning process. So thank you to all who have put in your two cents. You make very valid points. I don't want to undermine that or sound condescending in any way. I simply want to understand more than from my own perspective.
- Likes 1
Originally posted by JZRepair View PostAs for balancing, yes, 1kHz signal and looking for matched clipping makes sense, but in all reality, matching the tubes with current is a much better practice.
Tube characteristics vary and equal idle currents doesn't imply equal signal currents at full power.
Regarding max. clean headroom the Blackstar method is best.
Driving any amp at full volume, with a solid 1kHz signal for extended periods of time is going to damage the amp.
And yes, you should use a suitable dummy load.Last edited by Helmholtz; 09-25-2022, 11:01 PM.- Own Opinions Only -
- Likes 1
I think Blackstar (and other manufacturers like Fender) equip the amps with matched sets of power tubes and assume they will be replaced as such. Some of the fender amps also use the shared sense resistor for bias setting.
The idea that there is one single % diss. number that applies to all amps is a myth. Some amps are designed to run power tubes hot, some cool. Many, many vintage Fender amps sound just fine at 40%, definitely not garbage. Some of the music man amps idled at about 5%, should that even work? You can not judge what an amp is going to sound like at some idle % without even hearing it.
I generally find that amps can be biased a lot colder than I would think before it starts to have any negative impact on the tone. But that is not true for all amps.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
The different valve rating systems used should be borne in mind too.
For a given valve type, 70% of its design centre rating will roughly equate to 60% of its design max rating.
A 6L6GC isn’t really 20% more beefy than an EL34, it’s just that they’re rated under different systems.
Design max ratings are intended to be used in worst case condition calculations, whereas design centre to be used in nominal condition calculations.
Unfortunately these things get conflated, no distinction ever seems to be made, and there’s pretty much universal use of design max ratings for nominal condition calculations, eg every bias calculator on the web.
https://www.one-electron.com/Archive...on%20Tubes.pdf
- Likes 3
I bias tubes on the cool side. There's no right or wrong %, and for me tube life and reliability are important. I've never had one single customer complain that their amp sounded bad due to cool biasing. How cool depends on the particular amp, as well as the tube type. From the factory, many amps are biased very cool and this doesn't affect their reputation for being good sounding amps.
It's rare for me to balance tubes for maximum clean headroom, but doing this at the onset of clipping not only takes the tube curves into consideration, but also any other asymmetry or non-linearity that may be present in the rest of the circuit.. My dummy load will stand 2.5Kw continuous (dual fan cooled for PA testing) so guitar amp output hardly gets it warm.
- Likes 4
I tend to disagree.
No. If we're speaking of minutes not hours
As for dummy loads, I don't like them, because I can't hear what is truly going on. There are little things that can be detected audibly that I find much more helpful than using a dummy load.
Originally posted by g1 View PostI think Blackstar (and other manufacturers like Fender) equip the amps with matched sets of power tubes and assume they will be replaced as such. Some of the fender amps also use the shared sense resistor for bias setting.
Originally posted by Mick Bailey View PostI bias tubes on the cool side. There's no right or wrong %, and for me tube life and reliability are important. I've never had one single customer complain that their amp sounded bad due to cool biasing. How cool depends on the particular amp, as well as the tube type. From the factory, many amps are biased very cool and this doesn't affect their reputation for being good sounding amps.
Originally posted by JZRepair View PostI don't know enough about it. Can you provide an article to back this? It helps to see data.
I like to confirm power output using scope and dummy load. Easy, quick and reliable.
Sometimes reveals a flaw (like oscillation) that would not show otherwise.
Doesn't harm the amp to run at full power.
A class AB amp puts most stress on power tubes plates at medium output.
Balancing (or matching) at idle only covers one DC operating point. When tube curves are not identical, AC signal operation will not be balanced.
You can test at low volumes and get the same results you would see at higher volumes.
This said, balancing at idle is typically sufficient for a guitar amp.
After all some asymmetry at full power may even sound good.
As for dummy loads, I don't like them, because I can't hear what is truly going on. There are little things that can be detected audibly that I find much more helpful than using a dummy load.Last edited by Helmholtz; 09-26-2022, 04:43 PM.- Own Opinions Only -
- Likes 1
Based on own measurements since around 1980.
That's simple: If you need to hear, connect a speaker in series with a 100R resistor across the dummy load or use headphones with a voltage divider instead.
To me, through a guitar type speaker, a constant tone is intolerable at more than micro watt power.
Hearing is a consumable, I’m not wasting what little I’ve still got on that stuff.My band:- http://www.youtube.com/user/RedwingBand
- Likes 2
Originally posted by pdf64 View PostTo me, through a guitar type speaker, a constant tone is intolerable at more than micro watt power.
Originally posted by JZRepair View PostHowever, there is still the cost of the dummy load. These are not cheap by any means and even a DIY load is quite expensive.
- Likes 1
