hafler t2 preamp
  • hafler t2 preamp
    hello,can anybody tell me what the tt2/d.o.t.is on this schemo.baught this on ebay and this trans?/part is missing any thoughts?tried a reverb trans but thats not it.
    It is a small transformer. I'd say the OT in DOT means output transformer.
    Have you tried contacting the manufacturer? They might even sell you the part.
      hafler t2 preamp
      yes i tried hafler/rockford.they nolonger support the hafler.iwas lucky they could get me a schemo thats all the info they have.i have run into a brick wall on this unit,really sucks
        From the circuit position it is an output transformer, but the question is what the secondary should be rated at. What happened when you installed the reverb transformer? Too little output?
        The Fender transformer is rated something like 11K to 8 ohms. I would think that your circuit would probably need a higher secondary impedance.
          hafler t2 preamp
          yes,when i hooked the reverb tranny up it had almost no output.and i don't know how i can figure out the proper secondary.anywere i should start?also the orig.part was very small pcb mount type'pain in the ars!!!
            It could have been a line driver type, something like 15,000 to 600. 600 ohm lines are common. They come in pc mount small.
              Ancient thread I know but since I just fixed one with the same fault always good to share.
              The part you need is an audio transformer like this one from Mouser: Xicon 42TM117-RC.
              There are other suppliers too
