Need Schematic for Crate BV6212
  • Need Schematic for Crate BV6212
    I need a schematic for the crate bv6212. I mainly need to know the tube layout and which one is v1, v2, etc... I guess I could remove the chassis and look at the bottom of the PCB for id, but maybe someone can help me out? I got it used and it has 12ax7's in all 5 preamp tube sockets. I want to put a 12au7 in the v3 reverb socket, it is what is required, not a 12ax7. Dont know which one v3 is. Thanks,
    The BV60 is the same amp. Send me your email and I can send a copy.
      But the BV60H is not, so be careful.
        Bv6212
        I put the 12au7 in the right slot and also replaced the 12ax7's with JJ 12at7's and a new set of svetlana el34's biased at 60% and this amp rocks. Quiet at idle and the overdrive is just right. It was too nasty and had too much growl and hum before. I am looking into getting some 5751's to tame a crate vfx5112 that is on the nasty side of the bar as well.
          my crate bv60 head took a crap too anyone got the schematic they could send me? i think its a fuse but i could be wrong
            I'm seeking a schematic for a BV6212, also seeking the input/ouput voltages for the reverb unit, as mine came used and didn't have the reverb unit in it.
            Any help is greatly appreciated.
            casinolevant levant casino
