I was just going to suggest measuring DC on the output jack
. If you look at the schematic, please read the remark on bias adjustment procedure (bottom-right of the schematic). It says that the voltage accross J5 should read 10mV. I think that if you measure it, it will be much higher than expected. If this is the case, the protection circuit is working correctly. But be careful when adjusting R28 - the amp may be very sensitive to this (Teemu please correct me if I'm wrong). The voltage accross J5 is measured by following two transistors (I cannot read the symbols - the first one may be marked Q31) and if it's to high, signaled as a fault. I my opinion there is still some faulty transistor in the amp. But since the amp is almost simetrical, you can measure voltages on the (+) side and compare them to (-) side. Appart from this, there are already some voltages on the schematic.
Marek
Marek
