50hz vs 60hz Damage?
  • 50hz vs 60hz Damage?
    Hey everyone,
    I have a quick question. I am currently in japan and will be here for the next few years. I have a fender Hotrod Deville (2005) I was wanting to know if running my amp on the 50hz 100V (sometimes 110) will hurt the amps tubes or transformer? Can anyone help
    Thanks in advance
    I purchased the amp in the states
    It shouldn't make much difference. A transformer designed for 60Hz will run a bit hotter on 50Hz, but since your line voltage is only 100V instead of 120V, that should more than compensate for it and stop the transformer from overheating.
      Cool
      I noticed the amp sounds different after about 3 hours it sounds weak or les punchy. Maybe its just soo loud that I am getting deaf after the 3 hours
      Thanks for the help
