Hi all!
Just working on my Ampeg J12A the other day, which has a developed some sort of fuse-blowing short. I think I've found that the power transformer's bad, but I haven't worked much with them before so I wanted to do an idiot check with you guys before I drop $160 on a new one.
Here's the question: how does a power transformer behave when unloaded?
I'm worried that when I disconnected all the secondaries, the transformer will blow a fuse anyway because it's completely unloaded. As I understand it, when you connect your mains up to the transformer, the inductance of the primary should keep the winding from looking like a short between the line and neutral... but I have a nagging feeling that I'm forgetting something I learned 10 years ago.
Also, what's the best way to test that a transformer meets its specs?
Thanks for your help!!
