I have been troubleshooting a 93 Blues Deville that is dead.
I plugged a guitar cable into both input jacks and no signal, ( I tapped on the other end of the cable and it's dead.) I went to the output and put the voltmeter on the speaker jack. No click, I put the volt meter on the Plate (pin 3) of the output tubes, no audible click measured 470 volts dc, And then the screen grids of the output tubes and no audible click grids measured within spec. I tested the plates of the preamp tubes and they measured around 250 vdc. I tested the output transformer with an ohmmeter and it read about 150 ohms on the primary, less than 10 ohms on the secondary. By the reading I figure the OT is fine.. I went from the output all the way to the input and checked for audible clicks on the plates and grids of every tube. no audible clicking, which leads me to believe it must be the OT? The speaker cable and the speakers tested ok. Any help would be extremely appreciated.
Puzzled in blues Deville
