Morning. OK a Dsl15 on the bench blown fuse fs1. Tested tubes gone bad. Replaced tubes new tads 6v6. Turned on can see on switch on that too hot.
Found at the lowest I can only get to 40ma and rising. Then I saw that the 2 x 100k had been piggyback with 47k s. Removed and retest. Still the same really
B+ starts at 420 ish and drops too 385v
Bias voltage - 27v
-72v at point of d1/2
Tried 2 sets of good tubes
Removed all the ecc83
Heater on ecc83 6.5v dc
With all tubes out b+ is 424v
@ 420 v I should be around 20ma for 70%
Any experience chaps, care to help
Arbutt.
Will try and get map over shortly
Bias voltage - 27v
Arbutt.
