Dsl15 bias issue
  • Dsl15 bias issue
    Morning. OK a Dsl15 on the bench blown fuse fs1. Tested tubes gone bad. Replaced tubes new tads 6v6. Turned on can see on switch on that too hot.
    Found at the lowest I can only get to 40ma and rising. Then I saw that the 2 x 100k had been piggyback with 47k s. Removed and retest. Still the same really
    B+ starts at 420 ish and drops too 385v
    Bias voltage - 27v
    -72v at point of d1/2
    Tried 2 sets of good tubes
    Removed all the ecc83
    Heater on ecc83 6.5v dc
    With all tubes out b+ is 424v
    @ 420 v I should be around 20ma for 70%
    Any experience chaps, care to help
    Arbutt.
    Will try and get map over shortly
    Schematic attached.
      Thank you. I'm only on the phone at present and you beat me too it.
        What happens when you reset Trim 1 & 2. The bias voltage should turn to cut off point or at least very nearly but, if C9 is low value, there will be a lack of -ve DC for the bias.
        C9 should be of a suitable type and value!
          Hi Jon. Not with the amp at present. But with the bias at the lowest position. I have about 40ma on test points and that is after a very short time - 27v on the tube base.
            What is DC voltage at anode of D2 ?
              Hi g1. From memory it was - 72v.
              Many thanks
                Morning. We'll this morning I followed the advice and changed c9 and while I was there. Changed the 10uf 160v. All done.. Til next time.
                Arbutt
                  It’s good that this isn’t a manifestation of the conductive pcb issue.
                    Do you mean C15 22uF 160V ?
