Ashdown Fans - suck or blow
  • Ashdown Fans - suck or blow
    Hi there,
    Can anyone confirm which way round the fans in Ashdowns e.g. MAG300, EBM EVO are normally oriented... ???
    Mike
    Looking at my Ashdown files, one of my photos show the fan's MFGR circular label on the inside rather than facing the outside of the chassis rear. They look to be positioned to be blowing air into the heat sinks rather than exhausting the hot air from the heat sinks.
      I'm not sure if all fan mfgr's use the same format of airflow direction relative to the location of their circular mfgr label on the motor frame. In this case, the label is on the inside, and I do recall the airflow to be flowing INTO the heatsinks.
        Thanks... I agree with you...
        Having done more research...
        Trace Elliot (same designer in Clive Button) blow onto heatsinks and some photos on the web show fans with no label visible on the rear indicating cold air flow onto the heatsinks. Also I recall seeing lots of dust on the front vents on one of the big 900 ABMs once.
          The direction is embossed on the fan chassis. An arrow points the direction of the air flow.
