I had an old Blues Deville come in with a crackly volume pot, and visibly leaky filter caps. WHen I pulled the board the Vol pot was rocking back and forth, with lifted pads.
I replaced that, did the cap job, put it all back together, amp sounded great. No issues....
except that the Reverb worked when it came in, and now it doesn't. Here's what I know:
https://www.thetubestore.com/lib/the...-Schematic.pdf
-Tank works fine on another amp
-cables show continuity
-Footswitch changes channels OK but not Reverb
-I can hear the relay for the channel switch physically clicking when changing channels, but not when I turn the verb on and off via FS
-I'm getting a splash when I shake the take, so the return is fine
-When I plug in the footswitch cable when the splash is ringing out, it kills it immediately
-At TP 34, for " +15 Reverb off, -15 Reverb on", it just stays on -10 or +13, but this is effected by the channel switch?!?!? The reverb switch does nothing here.
Any ideas?
Any ideas?
