No problem going up in voltage on a cap, but why do you want to replace c9 and C10? They are blocking caps, do you think they might be leaking and affecting your bias voltage?
JCM 900-4100 head Red Plating Issue
I also want to replace C10 and C9 , they are rated 47nF /400v ... Can I use 47nF /630v? How can affect Using a more voltage version ?
So you will achieve nothing and you will learn nothing. With the help of schematic and a multimeter, do your best to find the CAUSE of the fault.
Random change of components (if you are lucky hands) only eliminates the consequences, the amplifier will work for a while, and since the cause is not eliminated, it will be returned as a complaint again for repair.
It's All Over Now
Originally posted by Randall View PostNo problem going up in voltage on a cap, but why do you want to replace c9 and C10? They are blocking caps, do you think they might be leaking and affecting your bias voltage?Last edited by moonmark; 09-10-2020, 02:07 AM.
Originally posted by vintagekiki View PostWhen an amplifier is defective, do not change the components by heart for no reason.
Random change of components (if you are lucky hands) only eliminates the consequences, the amplifier will work for a while, and since the cause is not eliminated, it will be returned as a complaint again for repair.Last edited by moonmark; 09-08-2020, 06:32 PM.
Hi all.
I have good news for you, the amplifier is working very well, no more Red Plating !!! Thank you Rich from Tonefinder.net, DrSonic from Guitarristas.info, Randall, vintagekiki, g1, Pedro Vecino from this site and Chris in LA, Iron1, anitolli, gunner64, mickeydg5 and Ken0418 from Marshall Forum. I appreciate all your time and effort to make this amp work again!
The damaged components were C12 and D1. C12 was suddenly behaving like a resistor and D1 was shorted.
As advised for you guys, I checked the bias voltage, first I did it without the power tubes and with the speaker connected. I spend 20 minutes, checking the bias voltage stability. Then I installed the 6L6GC again and I managed to configure it at -50volts, I have both tested on pin 5 of the sockets (between -49.79 and -49.96V) in the 4 tubes, and also on the union of r26 / r27,at that point there is 50.26v approximately. Is it normal for it to fluctuate between 49.98 and 50.31? I was manually using the test tip and I was not using any crocodile clip, my shaking hands may be to blame
After that I change c9,c10,c15 and c16 to give fresh caps to my amp, and made again the bias process.
In that point I have a question...... some schematics and sites suggest 60-70% of 30 watts for 6l6gc and this is like 18-21 watts, so it means voltage between -38 and -48V.
What do you think about it? Now I have -50.26 aprox.
I appreciate your guidelines to solve this problem. I have my amp back and ready to play
Any suggestions or recommendations before fully assembling the head? I have taken the opportunity to give it an internal cleaningLast edited by moonmark; 09-10-2020, 02:04 AM.
- Likes 1
"Is it normal for it to fluctuate between 49.98 and 50.31?"
-50v is just a round number, it is the idle watts you really care about. One set of tubes may require -48v of bias supply to make them idle at 60-70% (if that is your method of choice) and another set may require -52v to place them at the same idle dissipation wattage. So the bias voltage is just a means to an end to get your tubes biased where you want them. Plate voltage is another variable in figuring dissipation wattage. There are different schools of thought on this, but I generally will bias a Marshall such as this one at about 60% of max. diss. If it's off a couple of percentage points, I don't lose sleep over it.It's weird, because it WAS working fine.....
Originally posted by moonmark View PostIn that point I have a question...... some schematics and sites suggest 60-70% of 30 watts for 6l6gc and this is like 18-21 watts, so it means voltage between -38 and -48V.
These tubes generally is recommend as part number, so the replacement tubes reduces to plug and play.
If tubes not specified by the manufacturer are used, bias voltage need to be adjusted.
Bias voltage adjust the quiescent current for a given operating class (A, B, AB), and the specified bias voltage is only an approximate value in relation to which the setting should be started.
For the same anode and bias voltage, power tubes can have different anode currents, and before installation it is require tubes matching.
http://web.archive.org/web/20100923051727/http://diyguitarist.com/GuitarAmps/PT-Biasing.htm
http://web.archive.org/web/20100923053412/http://diyguitarist.com/GuitarAmps/PowerTubeBias.htm
https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/8554-about-biasing-tube-guitar-amplifiers
It's All Over Now
- Likes 1
[QUOTE=moonmark;n913119]
[QUOTE]
Yes. That's a difference of less than 1%.
Amp supply voltages vary along with mains input voltage. Short term mains voltage fluctuations of up to 3% are quite common (at least in my place).
Good thing is that when mains voltage rises, B+ goes up while bias voltage gets more negative and thus idle dissipation essentially stays the same.
- Likes 1
