So this just happened when I was troubleshooting noise on my live amp...
  • So this just happened when I was troubleshooting noise on my live amp...
ID:	914405 Click image for larger version
ID:	914406Ugh, The night was going so good. I was troubleshooting some noise issues, so my amp was live. I’d been able to isolate and solve it to almost zero background noise. But there were some final things I wanted to investigate.
    So I was reaching for some parts on the shelf over my bench; and as Im moving this small parts bin aside; these fuckers come flying down from the 3rd Rope like they were Superfly Jimmy Snuka. Before I knew it, they all managed to land right inside my live amp.
    As soon as I could I reached around and killed the power.....
    ugh. But Im calling it a night. Ill assess any damage tomorrow, as I pick up the pieces, literally.
    Whoops! At least is looks like the problem, if any, will be at the lower power end, not the mains input end. Good luck.
      Nothing terrible happened to the amplifier because the main cable was disconnected from the mains.
      Just turn the chassis 180 degrees, so that the parts that landed in the amplifier fall out, and everything will be as before.
      It's All Over Now
        I'm sure it's ruined and almost valueless now. I'll buy it for parts, say, fifty bucks? I'll even pay shipping. I'm certain this is the best solution.
          AC main cable not connected to amplifier, just a little chaos on the bench whom needs to be put in order.
          Fifty dollars and pay for shipping Click image for larger version  Name:	Razmislja.gif Views:	0 Size:	428 Bytes ID:	914436
          It's All Over Now
            He did say the amp was live when it happened. He then powered down and, I assume, he then unplugged it.
            My offer stands
              It was connected and turned on at the time.
              • vintagekiki
                vintagekiki commented
                Editing a comment
                I'm sorry, I didn't pay attention to detail
              Originally posted by Chuck H View Post
              My offer stands
              50% is an agreed deal. Click image for larger version
              The offer is highlighted, only SF to pack and ship.
              Fifty bucks is fifty bucks. Better something than nothing.
              It's All Over Now
                Ha, had something fall into an amp I was working on the other day.
                Luckily it didn't land on anything dangerous.
                If anything you probably just blew a fuse if something shorted.
                  Chuck, you wouldn’t want this amp. It uses EL84s
                    IF it were an SS amp it would be toast but being a tube one: very little possible damage , if at all.
                    probably works fine as is.
                      Just fire it right back up with all those parts in there like that? Probably the Mojo this amp needs
                      As an aside, before this happened, I was probing around different nodes with a shunt capacitor. I found that one of my 100k plate load resistors was causing %90 of the instability and noise issues.
                      It almost sounded as if every tube I put in that position was extremely microphonic and noisy.
                      But what's strange is that it was a new, modern 2W carbon film cap (I pretty sure it was a Multicomp). Has anyone else had a problem with these resistors in the past?
                      I was very skeptical that it was the problematic, but I swapped it out for a venerable old 120k/2W ECG metal film resistor (Corning). The big blue ones. Remember those? They're huge for 2W resistors by today's standars, but I loved those things. Plus,... I think they sound good (there. I said it.)
                      edit: this is the Phillips/Corning resitor
                        Blue isn't just the fastest colour.
                          Yikes, what's with those component leads sticking way out?
                          Work in progress?
                            Look at the wider photos in post #1. Those leads are from unused parts that fell into the chassis.
