Hello I had thought i was finished with this idiot of an amp, what the hell were they thinking when they designed it !!
It came in for terrible hum. Changed the tubes/ two o/c bias feed 220k and 2 x 10,000uf which had leaked.. replaced both bias caps as a matter of course
anyway all was good, Sounded good
On final test i notice that the EQ was not switching off, with the LED on the front Just dimming when you flicked the switch on the back ( On - Off - Assigned to R2)
mk4b.pdf
I foot s/w in the back and turned too FTSW still the LED is remaining on or dimmed, still EQ can be adjusted when it should be off.
At this point i do remember when i tested the amp at the start, i saw this , but didn't pay much attention
I have checked the voltage rails all present 5v/23v/12v
All functions are working apart from the EQ switching
Checked the switch on back - OK
Selected the external jacks and tested All working apart from EQ switching
I'M a bit baffled TBH - not hard to do
I feel like handing back, as it is, But i one last chance
any help is going to be well received
thanks in advance
mk4b.pdf
thanks in advance
