So I have a VTM that has developed a terrible 60hz (I believe) hum
Standard maintenance, tube socket + jack cleaning new tubes and filter caps have been preformed
Nothing looks obviously burnt, cold solder joints etc
I believe the problem is pre MV control because raising the pre / post controls raises the hum considerably. Plugging a cord into the effects loop stops it, but only if I ground the + on the cord by half inserting it into the jack. If I plug in and leave it dangling then it gets worse.
When I engage the first DIP switch I get a sizeable POP, this is new. This switch adds an additional 4.7k resistor in parallel to the 6.8k cathode resistor on V1b.
Because this pops I believe I have a ground problem somewhere. Pops in conjunction with switches like this, to my limited knowledge, usually means there is voltage being fed into the ground somewhere
Anyway I'm pretty handy at tube amp repair but the real deal is being able to actually know what it wrong and what to do about it.
I'd appreciate any help as to what my next move should be.
