POP when switching channels
  • POP when switching channels
    Are there any common mods to cure this? Amp switches channels via push/pull pot and a relay. Pretty loud pop when switching.
    The amp maker knows about this but wont offer any help and a schematic is out of the question . But offered to upgrade the switching if i ship the amp to him.......almost $700 !!
    I do see theres 35vdc at the pot switch .. heres a pic of the relay and i dont see anything else on the board as far as an optocoupler , etc...
    anything i can try ? Click image for larger version
    What amp is it.
    Put that info up so all can see how helpful they are.
      What amp is it.
      1996 Wizard 100 watt head
        This one in the link for 4800?
        geezz
          It seems there are several models and there are some schematics out there.
          Need a specific model.
          nosaj
            Modern classic 1 , 100w , single input , made in 96
              Can't find anything on that. maybe enough info can be inferred from the modern classic 2 link I posted.
              nosaj
                From what I can see in either schematic, the relay input comes off of a ,02 blocking capacitor.
                Check to see that that cap is good and Not passing Vdc to the relay.
                If the cap is bad and passing Vdc , well, right there is a possible source of 'popping'.
                  not passing dc
                    If it's like the schematic shown, the switching on the grid of V3b is a potential ( pun not intended) problem. There is always a small grid leak current which will develop a voltage over whatever resistance is present in the grid circuit. When the relay changes that resistance can also change resulting in a pop.
                    Try this, not perfect but it should do.
                    1. Add a 10nF in between the relay and the grid of V3b
                    2. Change the 2,2meg to 470k
                    3. Disconnect the 470k that goes to ground that is located after the rhythm master pot.
                      Originally posted by nickb View Post
                      If it's like the schematic shown, the switching on the grid of V3b is a potential ( pun not indented) problem. There is always a small grid leak current which will develop a voltage over whatever resistance is present in the grid circuit. When the relay changes that resistance can also change resulting in a pop.
                      i dont think that scem is accurate..... #2 and #3 you listed are not in the amp..i went over the whole board
                        Can you draw one up for us then since you have it in hand?
                        nosaj
                          nosaj
                          no time.........if it helps , it does this with ALL volumes on 0
                            Well thats no help at all. You say the schem isn't right. And you don't have time to help us help you. Sounds like a done deal..
                            nosaj
                              Does the relay coil have a diode across it in very close proximity, to kill the spike?
                              Is the supply for the relay adequately decoupled?
                              Are you sure that the 0V common of the relay isn’t contaminating the signal 0V?
